when you use propane Gas in your trailer
When I use propane when I go camping I
use the small portable unit
18
35%
Have a large unit at the front of my trailer
9
18%
I use a large unit but not up front.
3
6%
I have a gas line that is always attached to the galley
7
14%
I am still the old fashion type and use white gas only, propane and I don't get along!
1
2%
I attach the line when I pull out the equipment
7
14%
I use both
3
6%
I use all 3
0
No votes
I do something totally different see below
3
6%
Total votes : 51
Postby Ron Dickey » Mon Apr 01, 2013 10:11 pm
in the poll you can answer up to 3 questions.
When you use propane in your trailer how do you use it.
I mean it you have a large tank and it is in the font, is it connected to the back all the time.
Or do you just cook with the small guys.
I mostly use the old white gas stoves but have a backup small propane one too.
do you connect the gas line when you have stopped for camping or is it connected all the time.
I would like to know where or how do you store it can you add that below.
MY small bottles I keep in the boot up front.
I have seen some people with special carriers they made to carry 3 at once.
what do you do.
Thanks Ron :thumbsup:
121377.............134179.........134805
both side walls are up...cabinet needs stain.......ongoing 2.5 yr bld build as i find time..... Cross Bow in Build Journals....viewtopic.php?f=50&t=54108
Ron Dickey
Images: 706
Re: when you use propane Gas in your trailer
Postby GuitarPhotog » Tue Apr 02, 2013 12:06 am
I use 1 lb propane cans for my lantern, but run the stove and my fire ring off a 20 lb propane tank that I carry on the front of the trailer.
I thought about hard plumbing propane with quick disconnects for each appliance, etc. and decided it wasn't worth the small advantages. The added complexity and increased leakage possibility was one consideration, as was the cost of propane quick disconnects and hoses and.....
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby Shadow Catcher » Tue Apr 02, 2013 7:09 am
We have a 25# lite propane tank that is permanently attached to the three burner cook top and water heater and a small grill that plugs into a gas point on the side of the trailer. I also use the grill at home so used gas line quick disconnects.
I will be checking for leaks in the system shortly. Most of the joints are below the trailer so any leak is not likely to create an explosive situation and they are easy to check.
Last edited by Shadow Catcher on Sun Apr 14, 2013 5:16 am, edited 1 time in total.
Images: 214
Postby len19070 » Tue Apr 02, 2013 7:29 am
I use the small 1lb bottles, but I refill them myself at home from a larger 25lb bottle.
Happy Trails
Len
len19070
Images: 24
Postby davidniebeling » Sat Apr 13, 2013 10:39 pm
len19070 wrote:I use the small 1lb bottles, but I refill them myself at home from a larger 25lb bottle.
Happy Trails
Len
Hey Len, Can you explaine how to refill the 1# bottles using a 25# bottle. I am fairly new to this and I use the 1# for everything. I hate to waste them and just throw them out and would love to refill them, but I don't know how to do it safely.
Thanks, Dave
davidniebeling
Images: 50
Postby GuitarPhotog » Sat Apr 13, 2013 11:29 pm
There's an on-going discussion of this here, with links to videos, where to buy the adapter, etc. here
http://www.tnttt.com/viewtopic.php?f=2&t=6874
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby davidniebeling » Sun Apr 14, 2013 7:38 am
GuitarPhotog wrote:There's an on-going discussion of this here, with links to videos, where to buy the adapter, etc. here
<Chas>
:beer:
Thanks Chas! :thumbsup:
davidniebeling
Images: 50
Postby GerryS » Sun Apr 14, 2013 7:57 am
We have a 10 lb on he tongue that we use for cooking and heating water to clean. 10lbs last at least a week with a little to spare.
GerryS
Postby slowcowboy » Sun Apr 14, 2013 10:39 pm
S
Plans. there was supposed to be plans to be followed when I built this thing. Opps! AH, gee, tum,tee tum. I think I forgot about the plans 2 years ago. ------Tow vehicles, 1995 ford explore, 1994 ford ranger, 1993 ford F-150, 2009 4x9 Off road teardrop, on harbor freight greatly modified frame.
slowcowboy
7000 Club
7000 Club
Images: 166
Postby wingnut » Fri May 17, 2013 4:49 am
I have mount at the front of my teardrops to transport a #25 tank that is dismounted & is hooked to the stove for cooking.
wingnut
Images: 46
Postby Ron Dickey » Thu May 23, 2013 11:11 am
links to propane use.
http://www.propane101.com/propanetankdisposal.htm
http://www.doityourself.com/stry/8-type ... ne-tanks#b
http://coleman.custhelp.com/app/answers ... ZFlWcWw%3D
I tried to find a site that offered pictures of most types of propane bottles.
Maybe you know one ore have a picture of the ones you use.
Ron Dickey
Images: 706
Postby slowcowboy » Sun Jun 09, 2013 6:49 pm
I use just a small green coleman can on the teardrop all it powers is my rv 2 burner drop in stove top. I also got a couple of extra bottles floating around under the galley counter top to run the coleman propane skillet.
I might run a 5 lb bottle on propane tree to run a propane coleman lantern.
just deepends if I feel like propane or 12 volt for lights or crack the white gas out.
slow
slowcowboy
7000 Club
7000 Club
Images: 166
Postby AZ_Desert_Rat » Sat May 17, 2014 10:38 am
I installed a small 2-burner RV stove in my galley and a 20# bottle on the tongue. It is simple and I should only need to fill the tank once a year, if then. :applause:
Happy Camping & Building,
John (JC)
The Arizona Desert Rat 6x10' Cargo Conversion
The FunFinder a 19' Toy Hauler
An AZ Desert Transplant
Gallery: gallery/album.php?album_id=3168
AZ_Desert_Rat
Images: 55
Postby rowerwet » Sat May 17, 2014 7:17 pm
1 lb bottles, they are easy to store and transport and don't need any extra parts. we use the webber Q grill for camping, but have the grill set on a table outside the galley to keep the heat and grease from making a mess.
rowerwet
Images: 521
Return to User Polls
