lets talk about the best way to keep our teardrops dry
Let's protect our teardrops! Let's talk sunbrella, carports, sheds and garages..
Re: lets talk about the best way to keep our teardrops dry
Postby tim_hart » Wed Jun 12, 2013 6:04 pm
tim_hart
Paha Que...
Postby Martinjmpr » Mon Oct 28, 2013 12:14 pm
We just got a custom-made Paha Que cover and the fit is great! Pics will follow.
Our recipe for protection is the form-fitting Paha Que cover + an EZ-up type canopy. The canopy is held to the ground with 4 5 gallon buckets, each of which has a full 60lb bag of concrete in it, with a long screw in I-bolt (I put a bolt and a washer - the biggest washer I could fit - onto the I-bolt before I submerged it into the hardening concrete, so I'm pretty sure the bolt won't pull out.) Straps are ratchet straps and I plan on attaching it to the I bolts and to the frame of the EZ-up with snap links (or as you civilians call them, "Carabiners" :R ) so they can't accidentally unhook (we learned that lesson the hard way.)
BTW, those pop-ups can often be found at sporting goods stores, Harbor Freight or other stores on sale. I think if you're using one of those to protect your teardrop, you have to regard it as somewhat disposable. We've bought 3 in the last 2 years, and honestly, if we get a year out of one, and we pay $60 or so (you can find them that cheap on sale) then we paid $5/month which is pretty reasonable.
Martin and Liz and our new T@B Clamshell "Livia"
Our old Teardrop "bubbles"
Bubbles version 2.0 build thread!
Our Facebook group:
Colorado Teardroppers and Tiny Trailers Camping Group (FB)
States we've visited with Bubbles and Livia: Image
Martinjmpr
Postby GPW » Thu Jan 09, 2014 8:16 am
Well then , although it’s really nice to have a big shed or garage , that’s not always possible eh ? Our Foamie’ trailers live Outside ALL the time , rain (which we have a LOT of :frightened: ) , Heat , cold, storms ... No problems !!! One almost 3 years now ... still dry as toast inside !!! ;) Just sayin’ :roll:
JMHO : I really believe a skin or covering over the plywood relieves the surface areas that always seem to fail first , especially when placed under tension loads as in bent plywood applications ... :thinking: If the plywood doesn’t fail , there’s no leaks huh ?
Postby grantstew8 » Thu Jan 09, 2014 9:32 am
Depending on how protected the storage area is, you could use a coleman event shelter. From reviews, they don't like too much wind...
grantstew8
Images: 77
Postby rowerwet » Thu Jan 09, 2014 4:52 pm
I put a roof on my tear for the winter
two sheets of metal roofing, some conduit, and a bunch of scrap wood
114235
I'm not worried about rain from the sides, I could make the roof wider as the steel is overlapped more than it needs to be in the middle.
the whole thing cost less than $100
so far so good
rowerwet
Images: 521
Postby Redneck Teepee » Thu Jan 09, 2014 5:30 pm
I'm real fortunate to have a shop with what was once plenty of room when built 15 years ago, but now I'm going up to compensate for lack of room on the first floor.Image
Redneck Teepee
Images: 21
Postby inthewoods » Sun Jan 12, 2014 5:40 pm
We are trying this cover for our trailer's first winter outdoors. We bought a Classic Accessories "R-Pod" cover. It's apparently waterproof but breathable. All the RV dealers around me say they work and wear well. To get a nice fit since the Rpod is a much larger trailer than my 5x10, my wife and I took the cover apart and cut the cover down for a near perfect fit on our trailer. We are happy with the DIY mod to the cover and it worked out cheaper than having a custom cover made.
inthewoods
Images: 25
Postby tony.latham » Fri Jan 17, 2014 10:38 am
I talked to a local gal here that does a great job on sewing up boat covers. $400! or was it $500? Anyway, it was too much. I bought one of those RPOD covers from Amazon for a $100. I think it was a return.
I piled it onto my 5x10, marked it, cut some off the bottom, took some in at the corners and it's like a gal with a well fit prom dress now. It came out great.
Postby Ystava » Wed Jan 29, 2014 2:47 pm
I used this in my popup that was stored outside. Mounted it to a wide flat board and put it in the middle of the camper. They're usually used in gun safes, but with a low-volume camper like a teardrop, should still work to keep the mildew away. Needs a power supply though.
http://www.goldenroddehumidifiers.com/
Ystava
Postby tdprice54 » Sat Nov 15, 2014 9:23 pm
mikeschn wrote:
That would be perfect. Problem is, the village won't let me put one of those up in the back yard. :cry:
About 25 years ago I was building a carport for my 65 year old dad. It looked alot like the one you are showing Mike. We lived in a small town in west Texas. Some really nice areas of town, some not so plush. Anyway my Dad had a nice house and wanted a carport. We had a new city manger that had just hired in from suburbs of chicago. I was on the board that hired him but he did not know me from Adam. He pulled up as me and Dad were putting the finishing touches on the shed. He ask for permit,which we didn't have but my Dad explained he moved there the day he got back from WWII and didn't need a permit because he owned the property lock , stock, and barrell. The fellow said that carports were not allowed in that paricular sub-division. There were a couple of words exchanged and the new city manger/city inspector said he would have to take the shed down. A few more unpleasant words were exchanged and Dad told him his problem besides being a yankee from Chicago he didn't recognize a " covered swing set " when he saw one. Dad ask if there was a city ordinance against that. The CM looked confused and left. I had to hang a swing in the end and was never bothered again. This is a true story. You had to be there to see how funny it really was. When Dad sold the place 20 years later the new owner ask what the swing was for? You might see if your village has a sense of humor!! :thumbsup:
tdprice54
Postby mezmo » Sun Nov 16, 2014 2:07 am
Great little story tdprice54 !
Cheers,
Norm/mezmo
mezmo
Images: 194
Postby Shar » Mon Nov 17, 2014 7:58 pm
I built a hybrid foamie this year, and just tucked it away for its first winter. I used tarps, because I had them already and I'm not quite sure how much protection my little trailer will need. We get lots of snow in Alberta, but mostly the weather is dry and windy, with mold not being much of a problem. The roof of my trailer is angled, as well, so that rain will tend to run off it. I will check on it during the winter and see how it holds up.
tucked away for winter.JPG (66.77 KiB) Viewed 8422 times
Sheryl
Shar
Postby Wobbly Wheels » Tue Nov 18, 2014 9:46 am
For Sheryl and others using tarps on their TDs over the winter - don't you hate when the tarp gets beat up from the wind and the grommets blow out after a few good wind storms ?
We are full-bore into our winterizing and storing regime for customers' boats and it occurred to me that everyone might not know these little 'tricks' that will let the same tarp survive all winter, despite some wicked windstorms we get here on the wet coast:
1) Instead of tying the bottom down tight, use the lines to hang to hang bleach bottles a foot or so off the ground. Then add enough water to the bottle to give it a bit of weight (adjust to suit). This will give the tarp a bit of give when the wind blows and it won't get blown out and ragged.
2) instead of using rope or string to tie it down, tie a loop of shock cord (or a bungee) through the grommet, and tie your line to that instead. That too will allow some give when the tarp tries to inflate or lift from the wind, and it will suck back down again. Adjust the size of the loop and the thickness of the cord to suit (1/4" thick cord should be lots for these)
Let's hope everyone's TD makes it through the winter dry and happy till camping season rolls around again 8)
Wobbly Wheels
Postby Shar » Sun Nov 23, 2014 11:21 pm
Thanks for the tips, Wobbly Wheels! :thumbsup:
Sheryl
Shar
Postby McGuffin » Fri Apr 17, 2015 5:31 pm
Hi ,
I know I'm coming to this very late but... I have recently invested in a 20' shipping container so I can store my tear drop in. It was already sprayed with insulation so it's dry and snug. I,m going to fix it up with storage across the top like this:
The weather is pretty bad here in Ireland so it is not really overkill :)
Larry
McGuffin
Images: 211
Return to Teardrop Protection
