hashbrowns
hashbrowns
Postby slowcowboy » Mon Dec 08, 2014 10:11 pm
Any one good at hash browns? Slow
Plans. there was supposed to be plans to be followed when I built this thing. Opps! AH, gee, tum,tee tum. I think I forgot about the plans 2 years ago. ------Tow vehicles, 1995 ford explore, 1994 ford ranger, 1993 ford F-150, 2009 4x9 Off road teardrop, on harbor freight greatly modified frame.
slowcowboy
7000 Club
7000 Club
Images: 166
Re: hashbrowns
Postby nevadatear » Mon Dec 08, 2014 11:48 pm
Yes
nevadatear
Re: hashbrowns
Postby S. Heisley » Tue Dec 09, 2014 12:58 am
If you've got a waffle iron, it is perfect for making hash browns. Just spread a thin layer of olive oil in it and then put the hash browns in to fry...no spatula flipping needed. Just turn the waffle iron over like you would for a waffle. Because of the indentations, you get more crispy parts than you do in a regular pan; and, without as much work. This trick works with an electric waffle maker, too; but, you don't flip that kind and it cooks twice as fast because both sides cook at the same time. :)
Images: 492
Re: hashbrowns
Postby cherokeegeorge » Tue Dec 09, 2014 12:09 pm
Nope, still learning to boil water. :x
George
For info on hitch covers
Teardrophitchcovers.com
cherokeegeorge
A Merkin Indian
Images: 37
Re: hashbrowns
Postby VijayGupta » Tue Dec 09, 2014 6:37 pm
My favorite is Rösti, a hash brown dish that's very common in Zurich, Switzerland. That, and the chocolate truffles were my favorite things when I visited there. There was even a rösti shop at the train station that had about 30 variations of it.
You can add any number of things like bacon, other meats, egg, cream, cheese, etc., but we like them just fried in butter. Probably have them most often accompanying grilled boneless pork chops. [darn, now my mouth is watering]
The secret is to boil the potatoes for about 10 minutes, then remove from the stove, drain, cool in cold water for at least an hour. Grate some onion and the potatoes. When we make these at home, we use a food processor, but on the road a grater would work, just slower. When ready, heat a (cast iron) skillet and add a few pats of butter. Toss in the potatoes and onions, press down and leave alone, then cook on low heat for about 15 minutes until the bottom is evenly browned. Put a large plate over the skillet and invert the skillet so the potatoes end up on the plate. Put the skillet back on the stove and slide the potato "pancake" back onto the skillet, uncooked side down. Cook for another 10-15 minutes. When ready, cut into wedges and serve.
I'm sure this procedure could be adapted to a dutch oven, but I hate to speculate as I've never tried it.
http://www.saveur.com/article/Recipes/Rosti
VijayGupta
Re: hashbrowns
Postby AZ_Desert_Rat » Tue Feb 17, 2015 9:36 pm
Wow VijayGupta,
Those sound really good!! I am not the cook you are and probably a bit too lazy.
:oops:
I just wash the potato (using a brush), grate it (peeling and all), place the grated potatoes on a hot cast iron griddle with a little olive oil, use a spatula to round the patty and flatten it out, and cook the first side until golden brown ... then flip the patty over to brown the other side. It is quick, only taking a few minutes, and tastes great.
8)
Happy Camping & Building,
John (JC)
The Arizona Desert Rat 6x10' Cargo Conversion
The FunFinder a 19' Toy Hauler
An AZ Desert Transplant
Gallery: gallery/album.php?album_id=3168
AZ_Desert_Rat
Images: 55
Re: hashbrowns
Postby AZ_Desert_Rat » Mon Feb 23, 2015 12:51 pm
Hello Slow,
I just want to jump in and compliment you on coming up with ideas for conversation and then keeping it going if needed!! It is this that helps keep this site at the top of the list!!
Great job :applause: :applause: :applause:
John (JC)
AZ_Desert_Rat
Images: 55
Re: hashbrowns
Postby 39Ratrod » Mon Feb 23, 2015 10:22 pm
I think Slow has left the building. Says user does not exist?
The biggest difference between a dreamer and a doer is the follow through.
39Ratrod
Images: 71
Re: hashbrowns
Postby S. Heisley » Mon Feb 23, 2015 11:58 pm
Let's just say that Slowcowboy is taking a sabbatical of sorts. ...Don't know if he will come back.
Images: 492
Re: hashbrowns
Postby AZ_Desert_Rat » Tue Feb 24, 2015 8:21 pm
Thank you Sharon,
I did not see that before ...
John (JC)
AZ_Desert_Rat
Images: 55
