KTM_Guy wrote:If you can go 4-5 days at a toasty 60-65 degrees on one battery charge why look for another option? Add another battery or a solar panel for more days out.
Todd
Squigie wrote:They have long startups with 'high' amp draws. And they all seem to draw too many amps when running, for my liking.
KennethW wrote:This is what I am going to try on my tear drop. It is a small version of the warehouse heaters. It uses a propane torch clamped to a conduit union with of piece of conduit going across the top inside of the teardrop with a florescent light reflector over it that will be painted silver.
I will use stainless steel dog dishes with a hole thru the bottom as wall thimble mounted to the wall
